SignUp Now!blms are right there at 124 int 128 at idle warmed after driving pulling in driveway putting it in park its within 10 +and -.. i do smell like raw fuel but i checked theres no leaks fuel lines rail regulater it smells like its coming from the charcoal canister ,also questioning my 4''mega maf i heard something about using the gen2 you have to have the 1.2 version or somthing.
"it smells like its coming from the charcoal canister". If the canister is getting gas in it, you may have a tank vent issue.
[That's where the tank is vented thru.] Once the car runs for a while, there's a vacuum in the tank. That will cause low fuel psi, cavitation, overheated pump.
Fuel psi cold, vs when the problem starts, is?
