Hi have a octane question about chips. I have a 100 chip says boost 23#
Also have a 112 chip that says boost 24, 25#
Is heat the issue dutt stock intercoolers? Figured with 12 more octane points you could run more than 2 more pounds of boost. Timing is the same.
Is it the heat that COULD cause knock after 25 pounds with dutt neck with 112 octane?
