Odd noise when I kill the motor
TType85
TurboBuick.Com Supporter!
Getting an odd noise when I kill the motor
Any ideas?
How long has the car been doing that? Sounds like the starter is engaged or engaging. Either that or a bearing is going bad in something but you would think it would be making that noise while it is running. Doesn't sound good whatever it is. Where is the sound coming from?
I just got the car back together from a front cover/oil-pan removal. It could be the starter as I replaced it with a new gear reduction unit when I put the car back together. The original did not use a shim so I didn't put one in should I have?
The sound seems to be on that side of the car.
put a washer on each starter bolt and re check, easy enough...
Bryan
If it is the starter I am 2 for 2 with "odd sounds" on the board today. My ears must be working good today.
Remove the serpentine belt. That will tell you if it's external.
That's sounds bad!! Check the turbo. Also could be something in the transmission. I had a 700r4 in my cutlass that made a similar noise when it fried. Sounds like something is spinning and fast.
New trans, that shifts good. I checked the fans. It only seems to do it when the car is cold. I took it around the block today and everything seems to run fine. The motor has stopped moving before the sound stops.
When did it start doing this after the front cover/oil-pan removal or after you changed the starter. That would tell you where to begin to look.
did you get the correct starter?
Have somebody start and stop the car while you narrow down where it is coming from. Remove the pipe from the turbo inlet and watch the blades
I keep listening to it and it still sounds like the starter is engaged.
Bryan
All done at the same time.
I believe the starter is the correct unit. It has no issues starting the car. Turbo looks like it is spinning fine, it is still is spinning after the noise stops. That says starter to me.
The motor has stopped moving, cant be contacting the inspection cover if it is not moving.
I have the inspection cover off now. I'm going to try it again tomorrow as it only showed up when the car was cold.
Try giving the motor a little rev before killing an see if sound changes,See if goes longer or stays the same, Almost sounds pressure related. Your motor sure is violent when shuts it off ,it almost diesels
Put the car on jack stands and have some one start the car and put your hand on the starter as the car shuts off. That is the best way to truly rule out the starter. It also give you another position to hear the growl and could possibly help you tell where the noise is originating from.
If the engine has completely stopped turn the only thing that could still be moving is the crankshaft fan since it has a clutch and the turbo. Since you said the turbo spins freely I would also check the crankshaft fan if your car still has it on there.
