- May 25, 2001
Getting an odd noise when I kill the motor
Any ideas?
Any ideas?
SignUp Now!How long has the car been doing that? Sounds like the starter is engaged or engaging. Either that or a bearing is going bad in something but you would think it would be making that noise while it is running. Doesn't sound good whatever it is. Where is the sound coming from?
put a washer on each starter bolt and re check, easy enough...
Bryan
If it is the starter I am 2 for 2 with "odd sounds" on the board today. My ears must be working good today.
When did it start doing this after the front cover/oil-pan removal or after you changed the starter. That would tell you where to begin to look.I just got the car back together from a front cover/oil-pan removal. It could be the starter as I replaced it with a new gear reduction unit when I put the car back together. The original did not use a shim so I didn't put one in should I have?
The sound seems to be on that side of the car.
The motor has stopped moving, cant be contacting the inspection cover if it is not moving.Since you just dropped the oil pan it sounds like the torque convertor cover hitting the fly wheel.
All done at the same time.When did it start doing this after the front cover/oil-pan removal or after you changed the starter. That would tell you where to begin to look.
did you get the correct starter?
Have somebody start and stop the car while you narrow down where it is coming from. Remove the pipe from the turbo inlet and watch the blades
