Odd noise when I kill the motor
Tried a few times with the belt off. Sound is still there. This is so frustrating. Could the rjc boost controller make noise? Air leak in the actuator?
Went out this morning and tried a few things. Drive belt off, down-pipe on, no exhaust I still get the noise. I took off the wastegate actuator arm and the sound does not happen. Put it back on, I get the sound. WTF....
Puck on the downpipe loose?
Its a TH DP and the puck seems normal. It only does it when the car is cold (after starting it 5-6 times it will stop till it is completely cold again)
