OEM Valve covers with Aluminum Heads?
GNICETRY
Cat&wife post starter
Do the OEM valve covers fit any aluminum heads? In particular the first sets made by M & A I believe.
The early M&A heads use a special valve cover which has 2 long bolts on the center of the head and an O-ring seal for a gasket.
The head has a groove on the sealing surface which is for a special O-ring.
The M&A valve covers will accommodate the pedestal rockers.
Can you use/modify OEM valve covers on those M & A heads?
I have a set of M&A heads with no valve covers, and I am considering modifying a set of TA valve covers to fit.
