turbobitt
- Feb 14, 2002
I am still batteling my off idle stumble with little improvment. I have maxed out both map and tps rate of change tables with no effect. AE vs. TPS position is set to 100% for most of the TPS range. I can cause a over-rich condition if I stab the throttle but my problem happens when the throttle changes very little which always results in no ADDITIONAL AE FUEL.
For example , If I slowly ease into the throttle , lets say 2-3% change, I get no AE fuel or map AE fuel and DELTA MAP and DELTA TPS remain 0 even though I can see a change in both TPS % and map. How can I change the sensitivity of the system to react and fix the problem??
Also , No vaccum leaks, Full tank of fuel, good fuel pressure, car runs well eveywhere else.
Allan Gorneault
Allan Gorneault
