i need to let it go
i dont have the vin on me right now i am in iraq but i could get it for you and some one will be home if you want to check the car out it does not run.
buyer responsible for shipping or picking it up
the parts that were installed on this car were all baught new and have less than 2k on them.
i know ill be forgetting alot of new parts on it but from the best of my knowledge here it goes
1987 turbo t we-4
ENGINE
.30 over
comp 206/206 ductile cam
morel roller lifters
chromoly pushrods
6 rocker arm supports
weber front cover and oil pump
arp head stud kit
arp rod bolts
comp 941 valvrsprings
roller cam button
je pistons pins and rings
felpro 9441pts head gaskets
rjc engine girdle
rjc girlde arp hardware for caps
te44 turbo
with adj wg actuater
MISC.
42lb injectors
accufab adj fpr
ac delete pulley and ac removed except for the box
kenwood head unit
30 psi boost gage
volt gage
scanmaster the newer one forgot the number
new starter
new tie rods
razors alky kit installed but needs to be looked over
2 turbo tweak chips
new cam sensor
new tps
new plugs wires gas filter
new shifter cable
TRANS
dave husek built 200r4
hardened shafts
hardened forward drum
trans oil cooler
vigiliante converter
3200 stall
lock up
the rear is original changed the fluid no whining or clunking or any problem with it.
APPEARENCE
front blinker shades
5% tints all around except windshield
black american racing rims
new and painted bumper fillers
what it needs
i came to the verdict that my engine builder put the timing chain slider the plastic piece back on with the double roller.
it wore the plastic down shredded it into the engine broke the holder got caught in the chain popped the camsensor out and most likely jumped a tooth. theres oil pressure and compression though all 6.
turbo needs to be rebuilt smoking at idle and fan touching housing
tires
cross member needs to be replaced
rear passanger body bushing needs to be replaced
catback exhaust
upper a arm bushings
5000 OBO
pms only i have no phone right now
car is located in north jersey
its taking extrememly long to upload pics right now, considereing its 128 kbps in my chu, im going to get some more up
1987 turbo t we-4
ENGINE
.30 over
chromoly pushrods
arp head stud kit
arp rod bolts
roller cam button
rjc engine girdle
te44 turbo
MISC.
42lb injectors
accufab adj fpr
kenwood head unit
30 psi boost gage
volt gage
new starter
new tie rods
2 turbo tweak chips
new cam sensor
new tps
new shifter cable
TRANS
hardened shafts
trans oil cooler
3200 stall
lock up
APPEARENCE
what it needs
tires
catback exhaust
5000 OBO
