I am back again......after posting some pics and getting some feedback on what I did to solve my passenger side leaking valve cover breather, (which was to use some valve cover baffles to stop the leaking), I decided just to replace my current catch can with a vented one and replace my metco breather (on the passenger side) with a closed breather that has a pcv port on it. This was my previous post:
http://www.turbobuick.com/forums/th...on-for-valve-cover-breather-oil-leaks.422185/
So, I got a response that said baffles won't allow enough air flow to allow proper venting of the crankcase. I measured the cross sectional area of the baffles vs the metco breathers and they are almost identical. But in the end I winded up purchasing another catch can. So, yep "GNONYX" you were right, I should 've just purchased the version 2 in the beginning
My question is......how should I route to my catch can now that it is a vented can (are there any changes) And have a closed passenger side breather with a pcv port on it?
My current routing should posted in this thread somewhere, but here it is :
Stock pcv to "in" port of catch can, then from the "out" of catch can to rjc racing pcv, then into the throttle body.
I am thinking that the valve breather line needs to be "Teed" into the pcv line, from there the line will go into the "in" port of the catch can
can someone help me out? ......i have asked this question before and have gotten no responses. :-(
