oil cooler lines same size
mikeA
Are the threads on the lines the same thread behind the filter? I know they are the same at the radiator... I'm makin custom fittings and don't hve both lines handy. Thanks for anyone that answers.
The filter adapter takes 1/2 NPT
If you're making braided lines you'll need a pair of 1/2NPT to -whateversizeyourlinesare adapters.
I'm making custom fittings. To hook up a oil cooler with -10an fittings. I don't want to have to make 2 diff ones.
Then you'll need two 12/NPT to -10 fittings for the oil cooler adapter. Then what every fitting you need on the other end to hook to your oil cooler.
So they make adapters like that? F@#$... Thank you.. I 'll look into it tonight. Is it pipe thread on the -12an side?
It's pipe thread to -12. The lines have a non swivel 90* -12 end on that side.
The other end is just plain ole -12
