I'm looking for the correct size plugs for capping off the factory in/out ports where the factory oil cooler lines hooked up. It seems to be 3/4" in size but was told the threads are JIC? apparently that's somewhere inbetween NPT and standard threads...
I want to retain the sandwich adapter so I can run the bigger oil filter using the RJC adapter and am running a deep sump pan ( thanks Kip )
