can someone described exactly what to do to block an oil filter bypass valve.
here is what I believe ..correct me if I'm wrong
remove the metal/ rubber spring loaded bypass plug in the oil filter adapter right by the threads that hold the oil cooler adapter on
tap that hole for a pipe plug
plug it with pipe plug and some sort of epoxy or locktite?
