I am going to run a remote oil filter braket that is made by CV Products. there are 5 different types oil filters that i can use. The major difference in the oil filters other than size is that some have an oil bypass set at 8-11 psi, 18-22 psi and one filter does not have any bypass.
Also, anti drainback. Does this mean that the filter has a 1 way valve that will not allow oil to drain out of the oil filter once the engine is off? But what if the filter is mounted with the opening facing up, then that shouldn't matter? Is that correct.
