Oil filter opener
gnx139
Any one know who sells the tools to open up an oil filter. I've checked the usual places NAPA, Bennet. Or is it in a special catalog like McMaster?
Open up? as in cut in half? or to drain oil so it dont run down all over everything?
I hit the end with cordless drill and let most drain out before removing filter
cut in half...use a Ginsu..I seen it on TV
"open up" so as to examine the filter paper to see if there is any metal particles present , cutting with a ginsu would defat that purpose
heres a link to the tool that cuts the head off
Summit SUM-900510 - Summit Oil Filter Cutters - summitracing.com
I have the Summit tool. It works very well. Opens up an oil filter like a can of soup.
I got a good size pipe cutter with the wheel and a vise at Home Depot for $20
I'll try it and see how it does.
I used to use my hands to open it up but that got boring so now i use my teeth. I found it works better.
i've got several size Ridgid pipe cutters---NONE of them work as easily as that specialized tool----it makes opening an oil filter as easy as opening a soda can...........RC
