Took off the headers to check for trueness and discovered 1 of the exhaust ports was wet 360 degrees inside with oil. Looked at the valve with a mrror and it is dry on the stem and the valve head. The port inside the header is dry also. Would this indicate a leak from the valve cover into the port ? The motor does not smoke at partial or full throttle but if left at idle for a will give a puff of smoke when you rev it up. No smoke when you start the car either. Thanks
