BennyBuick
- Sep 10, 2014
Recently bought highly modified 87 GN. Leaked oil all over driver side engine compartment... steering linkage, headers, dipstick sleeve, under carriage, etc... just fresh oil all over. Also, under heavier boost, smoke just pours out the back. So first, I wanted to eliminate the valve cover gasket, so I replaced that. The one on there was a metal one with the blue rubber on each side. Possibly not the best gasket selection as the head and valve cover both have rough cast finish and are not machined smooth, so I thought it best with an old fashioned cork gasket to form more to the rough casting finish. Cleaned up oil a bit best I could and went for a ride. Again, under boost, smoke pours out the back. I don't know if its oil spraying out somewhere onto exhaust and that is causing the smoke or if it is actually coming out of pipes.. Anyways, I check under the hood and of course there is fresh oil all over again. I'm super bummed. My brother points out that the dipstick cap is covered in oil and suggests taht is the root. So I put a rubber cap on it instead of the loose fitting dipstick head. This is how hte previous owner had it, anyhow, cleaned up oil, went for a ride and got on it quite a bit. No smoke even under full boost, I get back home and no fresh oil in engine bay. So maybe that solved the problem.. Any thoughts? If it is coming out of the dipstick sleeve, does that indicate excessive crank pressure. If so, is this bad, or indicative of a bigger problem? Also, I do get a bit of knock here and there under boost. the worst I saw was on the last ride and it pegged at 4.7 degrees. Do I need to be worried? I've also been told not to freak out that false knock is common with the headers being bigger than stock and so close to block in the close quarters of the engine bay. I'm not educated on such things and just learning. Other times knock registered, I think the most I saw was 3.4, other wise it was 1.2 and 2.3 I think. Any thoughts or advice?
