84' TurboRegal
Only a 6 cylinder?
- May 31, 2010
Hi, Im new to the world of turbos. I just bought my dads 1984 Grand National... It is leaking oil from somewhere, i did the valve cover seals, and that did not help. I'm pretty sure its not the rear main seal because the car only leaks when you hammer on the gas and the turbo spools up. I suspect the culprit may be the turbo oil return line? or a rear intake manifold gasket. I'm not very familiar with the turbocharged 3.8, however my 85' Limited had the 3.8, and i would assume the engine is very similar to the carbureted version.
