Set oil pump thrust clearance between .0005" and .0015" The tighter the better. I have even lapped the face of the gears in place. I usually have to machine the timing cover flat, too. The cover face is not parallel to the gear face. (especially on the aftermarket timing covers.
) If the timing cover is still installed on the car, just use a thinner gasket. The TA set-up shims are worth the money. You can use plati-gauge to measure the thrust clearance if you don't have precision measuring tools. You want it tight, but not rubbing. It's not a five minute job to properly set-up a timing cover/oil pump. I have spent 4 hours just setting up an aftermarket timing cover. Those things are machined with an AXE!,
and cast with a very poor mold.
