WHATS UP GUYS...TODAY I PRIME THE ENGINE WITH THE DRILL TO MAKE SURE OF PRESSURE BEFORE I BUTTON IT UP AND LAY IT BACK IN ITS HOME ...SO I USED POSTONS REPLACEMENT COVER THEIR BOOSTER PLATE AND STOCK PUMP LIKE THEY RECOMMEMDED...SO THIS IS WHAT I GET AN INSTANT 100 POUNDS...D@$M....THATS KIND OF HIGH..OIL CAME UP TOO ALL THE ROCKERS AND EVERYTHING LOOKED GOOD BUT SHOULD I CHANGE THE SPRING I USED THE LONG PLAIN SPRING THAT CAME WITH THE KIT...SO WHAT IM SAYING IS SHOULD I TRY ALL THE SPRINGS TOO BRING DOWN THE PRESSURE TO SOMETHING A LITTLE MORE NORMAL.....
 ...SO I USED POSTONS REPLACEMENT COVER THEIR BOOSTER PLATE AND STOCK PUMP LIKE THEY RECOMMEMDED...SO THIS IS WHAT I GET AN INSTANT 100 POUNDS...D@$M....THATS KIND OF HIGH..OIL CAME UP TOO ALL THE ROCKERS AND EVERYTHING LOOKED GOOD BUT SHOULD I CHANGE THE SPRING I USED THE LONG PLAIN SPRING THAT CAME WITH THE KIT...SO WHAT IM SAYING IS SHOULD I TRY ALL THE SPRINGS TOO BRING DOWN THE PRESSURE TO SOMETHING A LITTLE MORE NORMAL..... THE KIT HAS FOUR SPRINGS TOO CHOOSE FROM.
