Royal-T-Ltd
- Jul 12, 2003
Maybe I missed it but did you ever put another sender or mechanical gauge on it?Hmm plugs are both in. So now im stumpped...
-Aaron
SignUp Now!Maybe I missed it but did you ever put another sender or mechanical gauge on it?Hmm plugs are both in. So now im stumpped...
Ps first oil filter was fine cut open nothing in it. Had oil pressure with both filters. Drove car 20 minutes with send filter on it after Hot it lost pressure. Like said pan is off now and I don't see anything that scares me.
I will check and see if gasketWhat about the pickup.
Are the bolts tite?
Is there a gasket?
Might you have experience w/ such a failure? If so,you mind posting what you experienced?I'd be replacing that pump. Especially since the Mellings pump has a history of failing. I just wouldn't be comfortable with it.
Glad to hear you got it fixed... Wonder what the cause was. Did the pump gears fail?Replaced pump did the earl brown mods to cover while it was apart. Packed sucker full of vaseline. Primed with drill and now has pressure. So started it and all is good again. So im assuming lost prime. I have running now for 45 minutes hot sits at 20psi . Cut filters open nothing inside.
Only other difference was put a ac filter on this time and not a wix
