turboreese415
- Jul 24, 2014
My oil pressure gauge reads 10 psi when car is warm this is at idle only is that normal
SignUp Now!10 30 amsoil dominator and when it drops that low that's when I hear knocking someone said it should be st least 4o psi at idle10 is a lil on the low side but is acceptable. A few questions tho.
Has it recently dropped to that psi when it was higher before?
What weight oil?
How old is the oil pump?
20psi at idle still is low who are I know more than you my friend cause before my grand national I was the mustang man and never seen my oil psi that low lolIs it the same person that told you the pressure should be 40 psi at idle also the one that had you run 10-30 Amsoil?
Put in regular 20W-50 oil and you may then be ~20 psi at idle?
This engine was designed 50 years ago before Amsoil and most other synthetics became popular.
I'm sorry still don't make sense that's a low oil pressure u idiotWhat a shame, you don't know your ass from a hole in the ground. Need to go back to your Mus- shit
20 psi at hot idle in gear is fine, 10 psi hot idle in gear is a bit low, but still ok, especially if your doing it on 10/30 oil.20psi at idle still is low who are I know more than you my friend cause before my grand national I was the mustang man and never seen my oil psi that low lol
It all depends on the engine. A tight engine can run damn near anything. A worn out POS in the hands of a newbie knowitall might need a pan full of gear dope.
