Oil Priming Help.
85HOT-T
OK so gnntype has a proceduure to prime the oil system, but what they do not tell you is were or how to hook the drill up to the pump.
Any one out there done it before or know how to do it please let me know. Thanks.........Matt
Remove the cam sensor. The bottom of the cam sensor connects to the end of the cam, and the oil pump shaft. The gear around the bottom of the sensor shaft is driven by the cam, and the slot in the bottom drives the pump.
I cut the handle off a big long fat screwdriver and put that in the drill, but you can buy a tool that does the same thing. Basically you stick the slot of the screwdriver into the tip of the oil pump shaft where the cam sensor would normally go.
awsome thanks a lot man i appriciate it. Want to fire that 'F'er up today. Thanks again
Also a Chevy oil primer works also.
Be careful with screwdriver method because the screwdriver can and will slip off.
Billy T.
gnxtc2@aol.com
