Oil problem
Notice in the link above, he used flared fittings not compression fittings. That would be the better method.
I have one more question about the oil mod. How much power will it withstand before you should put the right bearings in it?
Sent from
Whatever you want to make for HP it will be fine,
My engine has this done to it for oiling the drivers side lifters
and I am at 680 wheel which would be about 780 HP at the crank.
This is a legit modification, no need to overthink this.
[/QUOTE]
Pressured oil has no idea how much power you're putting out the crank shaft. Sending oil to that side of the engine is solely to oil the rockers and keep the tappets full enough to do their job.
