Yankee John
- Sep 17, 2008
After doing lots of work on the top end of my engine, I changed the oil yesterday after 500 miles on the "break in" oil, and noticed quite a difference in my engines oil psi after the change.
I was running the engine immediately after the work with Mobil Delvac 15w-40, ZddPlus addative, and a Fram oil filter, The cold idle psi was 50, hot idle was 13 psi, and psi at 2000 rpm's was 25 psi.
After 500-600 miles now, I am using a Purolator Pure One filter, and 15w-40 Rotella T with ZddPlus additive after I changed the oil yesterday, Now my cold oil psi is about 60, hot idle psi is 20-25, and psi at 2000 rpm is at about 35.
Why would my oil pressure change with just a different filter and brand of oil after the change???
John
John
