oil pump bolts
williambavila
William Avila (The Buick Guy)
how many oil pump bolts are ther i need to remove the adapter to pack it with vasaline and for the life of me i cant get this thing off. or is there a differnt way of doing this? i have a 1/2 " drill and i am turning it clockwise???
There are 6 bolts.
You can disconnect the upper oil cooler hose from the radiator and pour oil into it until it fills up then reconnect and then use the drill to prime the engine.
Here is the entire procedure to follow for priming without packing the pump with vasoline.
http://www.gnttype.org/techarea/engine/PRIMING.html
thanks man i just went and spun it for about ten min and walla it built up about 60lbs quick
