jpwalt1987
- Nov 9, 2003
Well I have read the earl brown front cover modification and studied the power source manual till I see it when i close my eyes
. The front cover is ported and smoothed but I am still debating one mod. plugging the oil bypass. From what i was able to see, if the bypass is plugged oil will still be able to go around the plug that has the pressure spring in it. Of course the amount of pressure the spring has will determine when it bypasses the oil back to the suction side of the pump. Am I thinking crazy or not?? just looking for some info and ideas. the motor will have .002 clearance on the mains and rods. the cam bearings are redilled with a .060 hole except for the front one.(still havent decided what i want to do with that one). It also has a solid roller cam. thanks, jeremy walters
