larrym
West Coast Newfy
- Jul 17, 2007
I'm looking to boost my oil pressure a bit until I pop the motor out for a freshen up this winter, new roller cam and possibly bearings didn't like how the rear main looked when I did the seal.
I'm installing a thrust plate on the pump, when I do this can I just disconnect the orange wire and spin the motor until I see oil pressure or should I pull the cam sensor and a spin it with a drill?
Right now my pressure is 60 at start up when it warms up its 25 at cruise and about 8 at idle the needle is jumping around a bit too this is new and kind of unnerving.
I do have some noise at the cam sensor when I listen with the stethoscope even after shimming the sensor, that's part of the reason its coming out, could be pump clearance, might be the chain, cam, a lifter on the way out needs an inspection for sure, compression test was good. I had the heads re worked last year.
