Oct 17, 2002 #1 C chascue Guest is there any way to prime a V6 buick oil pump other than taking it apart and filling it with vasoline....thank you , charlie...
Oct 18, 2002 #2 R RCI2990 buick fanatic Joined May 26, 2001 Messages 109 what i used was a tool that you use with a drill that goes down inside where the dist. is.it's best to use a variable speed drill with this tool.
Oct 18, 2002 #3 U unboostedV6 Member Joined May 25, 2001 Messages 276 I made a pump primer out of an old distributer shaft which works well, but all my pumps still needed to be packed with vaseline first. Otherwise, the spinning gears won't pull oil from the pan. GB
