Just got my short block back from the machine shop Friday, and this weekend I spent doing the clearances on the front timing cover and oil pump. As I was about to put the timing cover on for the last time, I noticed my oil slinger was missing. So I tore the house up, no luck, called the machine shop this morning, and they don't have it, plus they said it won't be needed for my application since I'm running a double roller, and I have a GM cover (seal on the backside) with a neoprene seal.
I went looking at previous posts about this, and some echoed the same thoughts that if your running a double roller, it will not work, it will interfere with the chain, and some said that it's main purpose was to deflect oil away from the front seal because all they had were the rope seals, and with the new neoprene seals, it's not really needed. So who's right?
My new short block build consists of the following: Steel Crank, K-1 Rods, Diamond .20 over slugs, center billit main caps and roller 206/210 cam. Front cover has Earl's oiling mods done to it and neoprene seal. :biggrin:
Steve
Steve
