Would it prevent an engine restart if engine is hot??
I am having this exact problem (engine starts fine when cold, runs fine until shut off, but then will not restart until it cools down) after an engine swap during which I installed a used oil temp sensor purchased from a forum member.
I've replaced the crank sensor and ignition module during troubleshooting with no change.
When engine will not restart there is no signal to the injectors (Noid light doesn't light), and there is no spark from the plug wires.
Thanks, Bob
Thanks, Bob
