Bob Mustic
- Jun 26, 2001
I have a Stage II motor in my Kit Cobra and have a question about oil for anyone that can help.
I use a Weaver dry sump (3 stage) oil pump on my motor. The motor is normally aspirated and makes 473 HP with a 4 barrel carb.
I currently am using 10/30 Mobil 1 oil. The engine idles at 800 RPM with 65lbs of oil pressure. Runs 75psi at 2000 and around 100psi at 8,000 RPM (had someone else looking).
What is the general opinion on running 5/30 with the above? 0/30? Would it gain any horsepower? Remember I can't simply "Turn up the boost" to gain power. I have to tweek the motor in any way I can to maximize the power.
Also I'm planning on using the dry sump pump to pull a vacuum in the motor. Do I need to have any kind of relief valve or "break" in order for it not to pull too much vacuum and possibly damage seals or the silicone at each end of the intake manifold.
Any input would be greatly appreciated. Remember this car goes up against Big Block Fords at the Cobra meets and you guys don't want a FORD to beat a Stage II RIGHT?
Thanks,
Bob
Thanks,
Bob
