- Jun 18, 2001
Seriously, I have spent more time and $$ on these wheels than I care to discuss and I still cant get them to freakin fit. The rears fit perfectly. I have all four fronts. I previously had the rear rims on the front with spacers I had custom made that where machined to be hub and wheel centric, super trick. Wheel fit great looked great was flush with fender etc. Only problem is the car has bell tech spindles and the tire would run on the steel inner fender going over dips and bumps. I even went to a 225 tire from the 245 and it didnt work.
SO I bought two fronts, had them refinished they look great. Mounted up the tires and now the freakin tire rod ends rub
I have NAPA heavy duty tie rods now Im thinking the rod ends are just bigger, IDK. Looking for suggestions other than run a spacer on the fronts.
A new set of Billet Specialties wheels are looking better and better.
Pic of fronts with spacer and rear rim and 245 tire
Rears fit perfectly this pic has 225 front tire which Im not a fan of
