dank GN
BlackArts Automotive (661)993-8277
 - Jan 11, 2009
I’m swapping to my stage heads and my 2 piece valve covers won’t work with the headers I have . Does anyone have a set of valve covers sitting on the shelf by any chance?
		Cooler charge and lighter for the revs they did. Valves are bigger and engines are freshened after each race. I wouldnt use them for a street car.I have a quick question. I was reading the specs on the Indy motor Buick ran in Indy car . Anyway I noticed they are running titanium exhaust valves instead of inconal is the reason for this the fuel they are running methanol ? If not what was the reasoning behind running that type of valve also can you run titanium valves in a motor that’s running strictly E85 ? View attachment 335262
What throttle body is that?I got my 4 bolt turbine housing all squared away . So now I’ll have my 7168 with a .96 A/r instead of my .85 3 bolt housing. So that should definitely help in the back pressure department .also got a tps that was specific to my throttle body which had to ship from Australia which was crazy imo .
It’s a super badass jenevy that has a progressive opening. It has very lil movement when cruising and down low driving but it snaps open quick when going WOTWhat throttle body is that?
Very nice.It’s a super badass jenevy that has a progressive opening. It has very lil movement when cruising and down low driving but it snaps open quick when going WOT
We bring the pain unto ourselves.Yea believe it or not I got it from eBay for $25the only thing that sucks was finding a dam tps sensor for it which I found one that had to get shipped fro Australia. And I still gotta figure out how I’m going to setup my throttle cable . I figure everything for these stage headed cars is custom in one way or another
50psi @ 1800*F, will do that!but I warped the std exhaust valves in GN1R heads.
		Okay guys here is a update on what’s goin on with my dam motor . I discovered my cam key was broken . And so that caused my all my exhaust valves to make friends with there respective piston. The piston was alil bit bigger then the exhaust valves so needless to say all my exhaust valves are bent . There is very light damage to the pistons. I believe they are definitely still runable . So my plans from here are to order some new valve guides and some exhaust valves . I do have a question about running bigger 2.02 valves in the intake side of TA SE heads . Has anyone actually ran them on there 4.1 and was it worth it going to the bigger valve ? Anyway here are some pics of the damage
