ek02
- Jan 31, 2008
I grind à taper on the threads of the cam side bolts so no matter where the bolt ends up they will clear the cam. My rod bolts torque to 70 ft lbs using the old moly ARP lube. The torque is probably more like 75 with the new lube, which I don't like as much as the old moly lube.
