? on electric gauge wires
sugarandopium
where were the spiders
"connect the white wire to dash lighting or switchable 12v light source
connect the red wire to switched +12v source and the black wire to ground"
So, the white wire can go to the fuse connections where the scanmaster is wired in, correct?
Can I tie those two wires into the same connector?
Where do I get the +12v source for the red wire?
The white wire cannot go to the fuse connection where the scanmaster is wired in. That's power. The white wire as stated needs to go to dash lighting or other lighting source.
Under the radio pod you should be able to see a grey wire hanging around, especially if you have a console. That's the power source for the shift indicator in your console. Tap into that for lighting source for the "white" wire.
The Red wire can get switched 12 volts from the fuse block. One of the ign posts.
whatever it is you're wiring up?
