The use / addition of a diode can serve the same purpose as the dash idiot light. Had the same issue on my car and that’s how I repaired it. Its worked well for about 12 years now. I also get the alternators custom built to my specifications. Not a fan of the rebuilt crap from the aftermarket suppliers out there. Parts are always loose inside causing typically causing the regulator to fail. My alternator consistently puts out 14.6 to 15.1 volts. I made my own volt booster too
Probably adds .5 of a volt on average. You can basically trick the regulator to charge based on battery voltage. It took me a while to figure everything out but it can be done.
