2 questions
First I bought the tv cable correction kit from bowtie overdrives. It came with a new slightly longer tv plunger spring. The instructions on their kit says install new spring. ? is I also bought the PTS shift kit and it tells me to just install part with old spring?
Do I use old spring or new spring and install part from shift kit?
Second ? is about the number of shims I used in the new adjustable pin with a GN servo. I installed all 4 thin ones and Ihave about .030 to .040 when cap and snapring installed. I never did get it to tight where I could not rotate output shaft backward in neutral.
Is this ok?
Thanks,
brian
Is this ok?
Thanks,
brian
