There were alot of things my car supposedly had and didnt have, and time keeps showing it all to be BS. Just takes 1 lying ass hole to start a lie that keeps passing from owner to owner.
Sucks when you pay top dollar for a car worth a little over half of what you paid. I wont be able to get anywhere near what I bought it for, when I sell it. Then you chalk up all the thousands Ive thrown in ontop of that.
Ive repaired a million little things over the past year to improve driveability, idle quality, power, etc. The thing barely ran at all when I bought it. The intake gasket was the last thing I hadnt touched. I pulled the intake off this weekend and they used a steel pan gasket. There was no gasket material anywhere. Just steel. Is this normal? They used some crappy black RTV that was floating around everywhere but not serving much of any purpose other than to make a mess. I used a Fel-Pro pan gasket kit that was of far better quality.
Much to my disappointment, the heads were not ported. Deep in there, it looked like they had done some VERY light bowl work with a die grinder, (so little its not worth mentioning) and from what i saw it didnt look like they had a clue what they were doing. Ill bet this engine wasnt even rebuilt like they said. Probably just a head rebuild. It looks like they may have used some stainless intake valves at least. So anyway, I ported about the last 1 1/2" inches of the intake manifold runners, since thats the main pinch point. I cleaned the whole thing up, painted it, replaced the PCV grommet cause the old one was rock hard and not sealing at all...pouring oil all over the place and leaking mad air. I decked all the surfaces (amazing how warped this thing was everywhere), and sealed it all up properly.
The car runs pretty good now. Idles really well. The main thing is that now I can tear the tires loose in 2nd gear from a roll just by giving it 1/2 throttle. For guys who have done this- How much power is in the job that I did? 30hp maybe? What kind of ET/Dyno improvements have you seen with champion irons? Pulling the intake off on this car was a major PITA compared to my old car, so i wont do this right away...let alone doing a PITA head swap. But I do want to port a set of heads and lay them aside for a rainy day.
