Well if the amps are too low on the alternator could that affect my voltage? What is the recommended amps on the alternator? Mine says 108 on the back. Also, I checked the positive and negative cables and the + is .02 volts and the negative is 0.00 volts. So, they are in good shape I would assume. When I have the car on I am still only getting 12.3 volts to the battery and alternator. When I took the car for a drive the scanmaster dropped voltage from 11.8 (12.3 with voltmeter check) to as low as 11.2. And the droppage usually happens when I give it gas or floor it. Now, I thought the volts would go up when you floor it because the alternator pulley is spinning faster creating more electricity? maybe I'm wrong. Please help.
I also have a post in the turbo section about a vacuum leak if anyone wants to chime in.
