Opinions on aftermarket intakes
karolko
Hello Boys,
my question is simple, what is your opinion on aftermarket intakes and the pros and cons for them.
i have champion irons on the car right now, and an building the engine to do high 9's. fast xfi will be in the equation as well if that really matters. i would like to stick to a 70mm throttle body jsut to keep the stock look and mounts
let me know what you all think.
Adrian
Best!
ran stock-OK, ported stock-better, Ported champion-Best!:biggrin:
at first that was what i was planning on buying, but then i found out there were more options.
So is the champion intake the big daddy of them all? and who sells them.
Adrian
I'm assuming you are referring to off-center blocks.
The new Champion intake is probably the best (only?) production intake available. It is a new casting. I have never seen one in person but imagine it is for the racers that must appear stock. Does this intake match the Champion aluminum head?
Champion also sells a stock Buick intake that they port (it requires a core). It is nice and matches the ports of my Champion iron heads. Should work fine for a street and many strip engines. Depends on how $erious you are.
Of course, there are fabricated sheetmetal intakes (Hogan, etc). Pricey but worth it for the deadly serious racer.
Conrad
