opinions on engine build
PHANTASM
POWERED BY POVERTY
i am getting my shortblock built as the crank broke in the last one.
the car has a te44 and 3" downpipe already with 42.5lb inj
i have some left over parts from before.
i have the following:
BHJ DAMPNER
FORGED STEEL CRANK (MAYBE EAGLE)
STOCK RODS WITH ARP BOLTS
JW FLEXPLATE
BILLET CENTER MAINS
so do i just use the stock rotating assembly with the billet mains?
or install the good dampner,crank,and billet mains and get diff rods?
i want to build it for when i change the turbo which i am sure i will do.
Make sure and have the block align bored (not just checked with a straight edge). Shop should check the crank journals specs for the bearing you will use. i used the coated bearings with a forged crank. happy so far. you should check all clearances when assembling.
Mitch
If you .....
think you will be getting serious in the future, I would consider the forged set-up. If cost's are a problem, you probably can get away w/the stock rods. It's the detonation that usually kills them. If you have an idea for a dream engine, then this would be the ideal time to start. These engines are $$$$!:eek:
GOING TO GO WITH THE STOCK RODS WITH ARP BOLTS,FORGED CRANK AND BILLET MAINS,BHJ DAMPNER AND JW FLEXPLATE.
might as well use the parts i have laying around.
should be good to 550hp
