I went with a solid roller from Comp:
230 / 230 @ .050" and with my rocker arms the lift will be .604". This will have 113* lobe seperation angle (this was the widest LSA they could grind the core to). This is using the Extreme street roller lobe number 4872 for both intake and exhaust.
This cam is more aggressive than I originally intended but by going to a solid roller I was able to put alot bigger lobe in the same space. The gross duration and overlap on this cam is about the same as it would be on a 218 hyd roller.
This is the first time I ever custom ordered a cam. If this thing doesn't work I'll have no one to blame but myself. I hope I didn't pick a turd!
Jason
Jason
