pure_boost
- Jul 15, 2001
I'm working on a senior project and need some sort of valve to control small amounts of alcohol. The alcohol will be gravity fed and each reservoir will have less than 1/2 gallon capacity. I was just wondering if the solenoid valve on the TR's is air only use or if it would hold up to alcohol running through it. The alcohol is the type that can be "safely" consumed.
So far, I've found other solenoid valves, but the cheapest was approximately $40 each and we need 5 of them. Any and all thoughts are greatly appreciated.
