Hi All
I have found a problem (maybe) while rebuilding my trans.
My ATSG manual says that the internal ring gear (#664) is pressed onto the outbut shaft(#665). Mine is not. The gear slides down to the next shoulder before it stops, PAST a groove that looks like it might take a snap ring???. I ask this because I thought the clearance between the snap ring(630) and the sel. thrust washer(631)was a bit much at final assembly. I will call Chris on monday.
