Over flow tank on TTA w/ALKY Control
Scott89TTA
TTA guys,
Where did you put the coolant over flow tanks on your TTA w/Razor's Alky Control kit? If you didn't use the supplied tank what did you use ? Some pic's would be nice :cool:
Thanks,
Scott
On my car I had it under the K&N on the drivers side. Then I got rid of it and used my OEM washer tank as the overflow.. put a barb into its rubber grommet. Car is never in the rain.. and dont use the wipers.
Hows that?
Hows that?
so you just lay the tank down flat/long ways ?
The washer fluid tank is pretty stealthy :cool: I like that idea...mine is never in the rain if I can help it either. Could still use the wipers if caught in the rain...no real need for washer fluid...I'l have to think about that some.
Thanks,
Scott
I put mine right by the pump on the drivers side. Sort of by the airfilter.
