I had an ATR wastegate before I couldn't all of sudden go over 10psi before the wastegate bleed off, opened to find spring was broke 3 place's.. well I replaced with new TIAL 38mm ... my MBC (manual boost controller) is closed during this. looks like a air line regulator... buries the boost on gauge with just a hit of the gas pedal.. now Ive tested vacuum running at a steady 16 inches of vacuum. the wategate top port holds vacuum, and side bleeds the vacuum off right away when pressurized. now if not mistaken the side port goes to atmosphere and top port goes to the boost gauge?? I also did not start out using the original banjo fittings, I used a brass nipple fitting for top and other was running from turbo housing through a earl steel braid line. which has been removed and installed the original fittings that came with the TIAL, but has not been run since last night to frustrated... at work...
