adjusted the brake switch getting only 6-9 volts on pin a and f on aldl connector car seems to ride fine until warmed up or after about 10min of driving after 2nd gear converter will lock and be a slug even if i drop to D (out of OD) still locks know what i have in mind is yes a short in the circuit but why only after 10-12min of driving does it do this? from initial start it wont do this....any suggestions?  yes i nkow the computer wont lock till operating temp is @ 140 degrees....but seems like im going to have to run a switch to prevent the computer from locking early or? Tcc apply valve stuck? solenoid doesnt seem to be the problem..? should i swap a spare ecm?
