overdrive not working again
1984 t-type
Murphy's Law
ok i took my car out yesterday to the exhaust shop, its right down the road form me and i didnt get a chance to notice if it was shifting into overdrive because it was a short trip in stop and go traffic at low speeds. after leaving the shop i decided to jump down the freeway to open her up a bit shes been sitting since late august, when at highway speeds motor seemed to be reving sorta high like its in the wrong gear. i took my foot and pulled up on the pedal and nothing, taped the breaks and no kickdown im sure it not going into overdrive. i had a problem before where it was slipping in and out of overdrive when on the highway but it seemed to clear itself up, what should i check or change ? cant really afford a rebuild at this point in time hoping this is something i can fix mysely. any help is appreciated, also if there is a member local who knows about transmissions who can come test drive it for me please get in touch with me. thanks
did you check the TCC switch on brake pedal? check the ecm sol fuse.. also did you try the paper clip trick?
