owners of ATR headers..
TType84
cookin with propane
any problems? other than being overpriced, i was wondering if there were any real problems with the pieces, like cracking and what not..
Mine developed a crack on the passengers side header within the first year, but ATR took care of it no problems. Others I know have had no problems with theirs. The headers are expensive but they are also very well made. All the welds are ported smooth on the inside for maximim air flow. The workmanship is outstanding, as you'll see when you get yours.
Ditto!
Sometimes a "bargain" is no bargain in the long run.
ATR headers are well worth the $$.
HTH :)
i know chris wilson's passenger side cracked also.they were nice looking tho.
ATR headers
I have a set new in the box We are going to sell. After the turbomotion problems I am going to convert over to the 86/87 set up and don't need them any more. I tried to trade out with ATR for a set of 86/87's but they would not do it. I plan on having the vender I got them from try ATR himself and if that does not work I will sell them on the board. I will say this they look great.
I think ATR headers are excellent, have had no issues here and the workmanship was top notch. :)
During the buildup of my engine I sent my ATR headers out to be Jet Hot coated back in 95. I have not had a single problem with them since.
We decided to coat ours as well due to the discoloring. Went with HPC coating. Did an excellent job.
What is the difference between Jet Hot and HPC coatings? I asked the local coater if they could coat mine to look like polished aluminum and they said the only way they would do it is if they coated the inside with a race coating to keep the heat buildup down so the outside coating doesnt peel and crack.
HPC coats jet engines parts thus the heat isn't an issue. They also did not recommend coating the inside due to the fact if it ever peeled it may be sucked into the engine. We had the down pipe, cross over and headers as well as the turbo housing done at the same time. Went with this vendor due to highly recommended and they could use a coating that would not be effected by the heat disturbution. The only colors though were black and I think a grey for the real high temp coating.
hey where can i purchase me some atr headers for an 85 ? or is there a website that i can go to and look at an actual picture of the headers besides www.atrperformance.com? any inif wellcome just to keep in mind if any in california even better for me thanx
