Oxygen Id. Ac Delco Afs 21
so why does the search onTB tell me 20 and 22 gnx i am confused,COULD it give false readings on scanmaster for 02s and blm???????? at idle
AC delco sensors have the purple wire. The afs22 is the GNX one, get that if your getting
car runs ok driveing around,but c counts are very slow ,I will remove it and put the right one in.........THANKS GUYS
I just looked and Razor says the 21 is the GNX sensor and another board member listed GM part numbers that matched the detailed PN for an 87 GN with afs20.
There was good detail in the post that called the 20 the GN sensor and if Julio calls the 21, the GNX sensor, I've got to believe him.
Per AC-Delco...
From the AC-Delco buyer's guide. The AFS21 Regal Applications (some data looks wrong, so take with a grain of salt)
REGAL (30) 1982-1993
1993 V6-189ci 3.1L F/I Vin T
1992 V6-189ci 3.1L F/I Vin T
1991 V6-189ci 3.1L F/I Vin T
1990 V6-189ci 3.1L F/I Vin T
1989 V6-173ci 2.8L F/I Vin W
1989 V6-189ci 3.1L F/I Vin T
1988 V6-173ci 2.8L F/I Vin W
1987 V6-231ci 3.8L 2 BBL Vin A
1987 V6-231ci 3.8L F/I Turbo Vin 7
1987 V8-307ci 5.0L 4 BBL Vin Y
1986 V6-231ci 3.8L 2 BBL Vin A
1986 V6-231ci 3.8L F/I Turbo Vin 7
1986 V8-307ci 5.0L 4 BBL Vin Y
1985 V6-231ci 3.8L 2 BBL Vin A
1985 V6-231ci 3.8L F/I Turbo Vin 9
1985 V8-350ci 5.7L Diesel Vin N
1984 V6-231ci 3.8L 2 BBL Vin A
1984 V6-231ci 3.8L F/I Turbo Vin 9
1984 V6-252ci 4.1L 4 BBL Vin 4
1984 V6-263ci 4.3L Diesel Vin V
1983 V6-231ci 3.8L 2 BBL Vin A
1983 V6-231ci 3.8L 4 BBL Turbo Vin 3
1983 V6-252ci 4.1L 4 BBL Vin 4
1983 V8-350ci 5.7L Diesel Vin N
1983 V6-263ci 4.3L Diesel Vin V
1982 V6-263ci 4.3L Diesel Vin V
1982 V6-231ci 3.8L 2 BBL Vin A
1982 V6-231ci 3.8L 4 BBL Turbo Vin 3
1982 V6-252ci 4.1L 4 BBL Vin 4
1982 V8-350ci 5.7L Diesel Vin N
WELL ,all I can say is i put the 22 in and my cross counts are cycleing perfectly,,guys dont put in a afs 21...only 20 and 22..I REST MY CASE
Interesting. I've been running a 21 in my 87 for over 12 years now. Still works perfectly.
Straight off of Turbo Regal Web Site
Oxygen Sensor, (Stock) 25162693 (AFS-20)
Oxygen Sensor, (GNX) 25162753 (AFS-22)
And that is a strong argument! :D
I am fairly certain that I just put a 21 in and it is reading great!
As I commented on Razor, based on his reputation, if I were to make up a name for TurboDave, it would be, The Tune Master, based on all his posts that I have read. So if he likes the 21, that says a lot...
